A 35mm SLR film camera introduced by Pentax in 1997. It features autofocus and is compatible with a wide range of K-mount lenses.
Overlapping frames and the slipping gear
Regarding "Overlapping Frames: The film advance motor also uses a press fit plastic pinion gear. If the gear starts to slip, the film will not be fully advanced to the next frame. When the next frame is exposed, it will overlap with the previous frame."
What do you do to repair this? Have you found a good Loctite glue for the plastic gear?
Score 1
Add a comment
1 Answer
Same as me
Add a comment
Add your answer
Stig Vidar Hovland will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 5
Past 30 Days: 20
All Time: 276
