Up to 20% off select tools
An upgrade of the Nintendo Game Boy Advance, the Advance SP was released, in North America, on March 23 2004 with a square structure and clam-shell design.
Gameboy advance SP Red Screen Tint
Hi, I bought this GBA SP 101 on ebay and it has this red filter on the screen and is mainly noticable on black screens. Is this caused by the ribbon cable or the polarizing film? Or something else?
Add a comment
Most Helpful Answer
Hi!
Could be both actually. Only thing to do is to disassemble it and check the ribbon cable and screen. Unfortunately, you probably need to replace the screen (cable is fused) to fix this.. Sorry!
Score 1
Add a comment
Here are some causes and potential solutions if your Game Boy Advance SP (GBA SP) screen appears red.
Possible Causes:
Inspect the Battery: Display distortions (including color tints) can occur if the battery is low or failing.
LCD Damage — A defect or degradation in the screen itself.
Screen ribbon cable problem; A loose or faulty ribbon cable is responsible for causing color distortion by connecting the screen to the motherboard.
Backlight Type: If you own a front-lit (AGS-001) model, the lit screen can on occasion
Add a comment
Add your answer
Sonrai will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 44
All Time: 734
