Repair guides and technical specifications for the JBL Synchros E50BT, Bluetooth over-ear headphones with 50mm drivers and 610mAh battery released in 2016.
Can someone help me replace my ear pads?
I have this exact model but after quite a bit of use the earpads began to tear off, i got new ones and fully removed the half torn pads that i had but now i can't seem to put the new pads in. I tried using the little dent in the case of the speekers but it wouldn't help, i tried streching the pads and putting them on the headphone but it didn't work either. any ideas? or am i missing something?
Score 1
Add a comment
1 Answer
You might be able to use some cheap replacement ones off of Amazon like this one: https://www.amazon.com/Pdflie-Replacemen...
If those don’t work, sometimes they have adhesion put on them to stay in place, try cleaning that off.
It could also be that the headphones were made to be unrepairable, in that case idk what you should do.
Add a comment
Add your answer
ido Shmuely will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 13
All Time: 160
