Up to 20% off select tools
Repair and disassembly information for the HMD Pulse smartphone. Identified by model numbers TA-1589 and TA-1594.
How to reset password
how to reset password
Add a comment
1 Answer
okay, there is some ways you can, but this is the only way i know, its the recovery menu, hold down power and the volume up button, (idk if this supports it, but if it does, you should go into a menu with some opinons with code looking fonts, now to select, use the power to press, and volume down and up to go up & down, and there should be a reset opinon to erase all data, sorry.. its the only way i think i know.. and if you have backuped data, you can do this if you decide to format this phone @olivernoble
Add a comment
Add your answer
oliver noble will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 40
All Time: 722
