Apple's sixth-generation smartwatch, with optional cellular connectivity, released September 18, 2020. Model A2376, 44 mm.
Watch not displaying battery level properly.
I just installed a new battery and the watch will only display 100% or 1%. It works fine and for a good amount of time, but doesn't give me much warning when it is gonna need charging.
Is there anything I can do to get the watch to display the actual power level or am I stuck with this?
Add a comment
Might be an issue with the battery monitoring circuitry
3 Comments:
That doesn't sound like something I can fix.
by
Did you find some fix for that? I just replaced my battery and it charges, shows 100%, then it shows the battery percentage as it should, unless it reaches 1% and shows 1 percent for another 6 hours until it turns off…
by
This seems to be a common problem with replacement batteries. The battery level indicator usually displays a random number that is not related to how much juice is really left. It can remain on 1% for a long time. Now it's stuck at 1% even if you charge it for the whole day. I guess that Apple Watch does not work well with non-OEM batteries, but that's just a guess.
by
Add a comment
I’m having the same problem too and it sometimes happens with the watch powering off after only about 4 hours because it goes to 1%
Update (07/28/25)
3 Comments:
I'm still having the problem. i was hoping it would fix itself but sadly it has not. I'm not sure if it is my fault, maybe i hit something while i was inside the watch.
by
I’m going to press ahead and get yet another battery replacement from ifixit and see if that works? I was able to get apple to run the diagnostic test in the Apple Store and it passed it.
by
I bought a $16 battery off of Walmart for my watch and now it’s charging and reporting status of charge
by
Add a comment
Add your answer
Rob M. will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 26
All Time: 339
