Capturing high-quality digital images is fast and easy with this state-of-the-art smart camera. Equipped with a 14.0-megapixel CCD, this camera is capable of capturing images with a resolution of up to 4288 x 3216 pixels.
How to replace broken battery door
How can I replace my broken battery door. Cat knocked it off the table and broke the battery door. I can get the same camera for parts but do not know how to actually make the repair without damaging the camera.
Add a comment
1 Answer
Chosen Solution
@cwcat you can use this guide Sanyo VPC-S1415 LCD Replacement and remove the back and front cover. You will see a small roll pin that holds the door in place
That pin needs to be pushed out to remove the door. word of caution. There is a spring between the pin and the door. Take a look on how it is placed so you can replace it, once you have the new door.
Score 1
Add a comment
Add your answer
CWcat will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 14
Past 30 Days: 28
All Time: 209
