Right side not working after removing jack
My JBL 950 NC have been working great with a Bluetooth adapter for my PS5, I connected them with the supplied 2.5 - 3.5 cable to my ps portal. Great stereo sound. However when I disconnect the cable only the left speaker has sound anymore, nothing from right. I have done factory reset, checked mono-stereo outputs but nothing works. When I plug back into the portal with the cable they have stereo sound again. So frustrating. Can anyone help please.
Score 2
Add a comment
1 Answer
Chosen Solution
This may be as simple as a slightly worn stereo jack in the headphone. All stereo plugs have three wires; L, R, and ground. You can see the male plug having a center, left, and right mechanical configuration with plastic spacers separating each part of the plug, The female jack is designed to mechanically switch between internal or external speaker sources of signals. When connecting the plug, the L and R circuit are broken to allow external signals to the speakers. When disconnecting the plug, the L and R connections are remade for internal signals. You'll have to disassemble the side with the jack to see it. Google images of stereo jacks. Most likely the R side connector isn't contacting its metal prong to allow internal signal source.
Score 1
2 Comments:
"Jiggery Pokery"
This is the name to the highly technical procedure I adopted after your explanation.
When you explained the issue I decided after taking it all apart and realising then was nothing I could do with out breaking the tiny circuit boards. To stick a small steel rod into the 2.5 port and Jiggery Poker it about.....Hey presto. That connector you said about has come loose and now I have great STEREO sound again under Bluetooth.
Thanks I would never have thought about that if you hadn't said
by
You 'Jiggery Pokered' it Mono!
by
Add a comment
Add your answer
Mono sound will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 41
All Time: 399
