How do I repair a broken hinge?
One of the monitor hinges is broken. I am unsure if it is a hinge pin or if the hinge has disconnected with the base. Do you have a repair guide and repair parts?
No guide for this as yet, here's the service manual, my be helpful: https://dl.dell.com/topicspdf/inspiron-1...
Have to work out what's broken - top cover/bezel, bottom case, etc
Depends on the design and the damage, I guess, but typically lugs break on bottom case/top case or top cover, so I'd start with removing back and checking for damaged lugs for the hinges on top-case or bottom case, then go to display assembly - page 41, to see if damaged lugs in top-cover, or wherever.
Past 24 Hours: 3
Past 7 Days: 5
Past 30 Days: 25
All Time: 372
