Replacement of laptop ssd
I want to replace laptop SSD but the screw of sed is worn out. It can't be opened. Suggest what to do.
For stripped screws there are tools called 'stripped screw extractor' or 'spiral screw extractor' or 'speed out' or 'easy out'. There are a few different forms of the tool but they do the same thing: bite into the metal of the screw so you can unscrew it. They aren't expensive, you can find them on Amazon or other places. Make sure to get a set that has a very small one and you should be able to get the screw out. Then buy a pack of replacement SSD screws (you can also get those on Amazon) and you should be good.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 12
All Time: 194
