Model A1502 / 2.6 GHz (Turbo Boost up to 3.1 GHz) or 2.8 GHz (Turbo Boost up to 3.3 GHz) dual-core Intel Core i7 processor with 4MB shared L3 cache.
2014 MacBook Pro not turning on
Hi, I have a Mid 2014 13” MacBook Pro and it is not working. I received it the other day and it actually turned on and got to the setup page but it turned off soon after and has not turned on since then. I have installed a new battery but it still does not boot. The charge indicator on the MagSafe 2 power adapter shows it is charging and turns green when charged. I can sometimes even hear a little wiz when I push the power button on the keyboard as if it is trying to start up. I have tried almost everything I can think of including SMC, power reset etc. When I attempt an SMC reset with the MacBook plugged in it does indicate to green then back to orange.
I have tried some troubleshooting steps. Only thing I noticed without taking the logic board out was some orange rust like look on the screw hole of the airport card.
Any help is really appreciated as this MacBook is in great shape and I'd love to get it working again.
3 Comments:
Try disconnecting the battery and then plug the charger to see if it boots..... but from the sounds of it there is a deeper issue that may require the help from @danj @oldturkey03
by
@livfe I have tried this and unfortunately it still does not boot. Which is why I would assume it is something to do with the logic board. What I don't understand is how it turned on for a couple minutes after sitting in shipping for 10 days.
by
@mason18946 I have had this same happen to me before and it is a mystery as one was working before the seller sent it to me.... it booted and then screen flicker and goodnight..... Maybe is was struggling and that was why they sold it before it went to sleep..... Sadly some people out there will do this.
by
Add a comment
1 Answer
Let’s try this again, disconnect the battery and anything else in the ports. Now press and hold the power button for a good 15secs that fully discharges the logic board - Hard SMC reset.
Now just plug in the MagSafe charger, at this point the system should spontaneously boot, did it?
If not it sounds like a messed up EFI boot loader. Apple did have a bad OS update release. What is the macOS release you are working with here. Did you do a OS update?
20 Comments:
Hi, thank you so much your response. This was already on Big Sur when I received it.
Just did what you mentioned, held power button for 15s, hard SMC reset, all without anything plugged in. Unfortunately nothing turned on or booted.
by
@mason18946 - Not sounding good here. With the charger plugged in what is the color of the MagSafe plugged LED? Amber or Green. If Amber let’s let it sit for a good four hours it should be green at this point, is it?
by
With the battery not plugged in, MagSafe LED is Amber.
by
@mason18946 - With the battery connected.
by
It turns green then to amber. Yesterday after installing a new battery it went from amber to green after a couple hours.
by
Show 15 more comments
Add a comment
Add your answer
mason will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 36
All Time: 635
