wont turn on at all
it has power because i cant hold down the power button and it has a white light for a second, while unplugged but doesn't do much else, the only thing I've really tried is replacing the cmos battery
Sometimes, a display goes out, or the connection is loose, and it seems the asset is not working at all. Try plugging in an external display to confirm that it is not your issue. It's something simple you can do to eliminate a potential cause. Next, you should probably look at built-in device check capabilities. Good luck
Try removing the battery from the back of the laptop and then putting it back on if not the pls send me the model number on the back sticker
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 23
All Time: 317
