The Sony VAIO Fit 14 (released in 2013) is a touchscreen PC Laptop used for everyday purposes. It has a 14'' screen, a slim build designed for transportation, and comes in many colors. (Manufacturer Part Number (MPN): SVF14AC1QL)
Why is my keyboard not working
The keyboard lights up but the keys themselves aren’t working
Add a comment
@oken try a USB keyboard and see if that works. You most likely have a failed keyboard. The keyboard backlight is a different circuit then the keys. Replacement keyboards are available at many places. For instructions on how to remove the keyboard. See if the instructions on the bottom of this site will help.
While you work on your laptop, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Add a comment
If your keyboard isn't working, first restart your laptop and check if the issue is caused by software or a driver. You can also try updating the keyboard driver or connecting an external keyboard to test it. If some or all keys still don't work, the keyboard may need professional repair or replacement.
Add a comment
Add your answer
Oken will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 17
All Time: 226
