Repair guides, disassembly, and troubleshooting information for the fourth generation Sony PlayStation 5 DualSense controller, successor to the DualShock series. Identified by model number CFI-ZCT1W and motherboard model BDM-040.
How do I tear it down
I need to know how to test it down
Score 1
Add a comment
Chosen Solution
Hi!
I think the most easiest way is to follow this guide: DualSense Controller v2 Motherboard Replacement
This basically tells you how to get to the last part. I know this is for the V2 controller instead for the V4, but the process is almost the same.
Score 5
4 Comments:
what is the diffrence bertween the v2 and the v4 coontroller?
by
Hi!
Minor differences. Just some other parts are used from another brand. Like the triggers and rubbers are slightly improved. No big changes.
by
Thats wrong. The whole motor/shoulder trigger assembly is different. There are no screws on the front side (where the buttons press against the board) and no metal axle for L2/R2 also the flex-connectors are just 3 pins
by
Hi! I'm sorry! You are correct! The difference between the V1 and V2 aren't that big. Later on they did start with the 3 pins! My appologies!
by
Add a comment
V4 has 4 wires instead of 2. also the flex cables are smaller.
Score 3
Add a comment
Add your answer
Tavin Bauerle will be eternally grateful.
Past 24 Hours: 20
Past 7 Days: 115
Past 30 Days: 432
All Time: 8,041
