Power on but no display
Score 2
Add a comment
Try disconnecting all devices and peripherals and reconnecting them again. The most common issue is a faulty hardware. So, try replacing it or check the troubleshooting errors. You can also perform a System Restore.
Add a comment
First, if you have an external monitor you can connect it using a cable, if the monitor can display what is on the laptop then the laptop screen is damaged.
Add a comment
Add your answer
kasiya mwanza will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 6
All Time: 297
