Usb charging port issue?
why is my phone not charging only when lying in certain position?
Replacing the charging port is the most common solution for the issue you're having. The charging port will need to be soldered on. Since it's a delicate job, either make sure you know what you're doing or find someone that can help you solder it on.
This is the part you need. but again needs to be soldered onto the board.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 16
All Time: 217
