1.4GHz or 1.6GHz Processor / 64GB or 128GB SSD
Display Assembly Compatibility (Swap Over) 2012 > 2010 Possible?
I have a near useless 2010 MBA A1465 that is working fine but the screen is having the brown stain and stage light issue.... I have a 2012 complete display assembly sitting here doing nothing..... without taking the 2010 apart, can the 2012 assembly (complete with all cables) simply be swapped over to the 2010?
Looking at the guides for 2010 and 2012 it looks like everything is the same? A slight difference in the AirPort cards position but the cables look like they will be the same length. The Antenna part is listed as a different item, BUT the connectors are the same just a small difference in cable length for the WiFi card..... I think 2013-2015 will not fit to the 2010 but the 2010 being a tad longer will indeed fit to the 2012......
Replacement LCD according to online sellers vary.... 2010-2015 / 2015-2017 which is somewhat confusing.
LVDS Cables according to Online parts sellers are compatible.
Left Hinge Assembly According to this seller are compatible.
I will just go ahead and try it when I have some time later this week, that way we will have a definitive answer :)
MacBook Air 11" Late 2010 Display Assembly Image
Guide
MacBook Air 11" Late 2010 Display Assembly Replacement
Difficulty:
Difficult
1 - 2 hours
MacBook Air 11" Mid 2012 Display Assembly Image
Guide
MacBook Air 11" Mid 2012 Display Assembly Replacement
Difficulty:
Moderate
40 minutes - 2 hours
Add a comment
1 Answer
Most Helpful Answer
As you can see the parts houses treat them as different
I don’t remember if it was the antenna / camera cables or the LVDS connection.
Score 1
7 Comments:
I have found that the BookYard simply list their parts according to the year of the model they came from and not necessarily by compatibility. I have edited the question adding more info.
by
@livfe - the LVDS cable is a straight through across the board so that won’t matter here. Apple altered the pin assignments a few times over the years on the cable. You would need to review the assignments from the schematics between the models.
by
@danj It gets confusing when sellers of parts list the LVDS cables as all being compatible, which makes no sense if the pins are in different assignments.... LCD's surprisingly have remained the same.on the 11" models from 2010 to 2015..... replacements for a 2010 through to 2015 the last year of production.... only a test will provide a positive result or a disaster lol
by
@livfe - The difference is within the logic board and the display the cable spans, not within the cable itself self.
While not the best example I can think of right now, think how a power cord can be used within a 120 Volt service as well as a 220 Volt service. But the device will either not work (220 based) if plugged into a 120 service or how a 120 device will go up in smoke if plugged into a 220 service.
The cord is not the issue it’s what it spans. Likewise the LVDS cable is the same just within the LVDS signaling. In fact! The same type of connection is used within both iDP and eDP signaling in laptops.
Here we can think of it like the different data rates of Ethernet (IEEE/ISO 802.3 spec) UTP cables, only the quality of the cable becomes important not its pinouts as long as it fulfills the TIA/EIA 568 standard as required for the given data rate.
by
@danj Theoretically it will work no? Would you try it, yes or no?
by
Show 2 more comments
Add a comment
Add your answer
livfe will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 27
All Time: 330
