The 2004-2008 F-150 truck was introduced in January 2003 for the 2004 model year as the redesigned eleventh generation of the F-150 lineup.
Headlight hi/low beam switch replacement
Replace hi/low switch on headlights of 2007 Ford 150 stx
Add a comment
1 Answer
Most Helpful Answer
@charlesharner sounds like you are talking about replacing the
Steering Column Multifunction Switch
ItemPart NumberDescription
1 W504041 Lower steering column shroud screw
2 3530 Lower steering column shroud
3 W506824 Upper steering column shroud screws (2 required)
4 — Upper steering column shroud
5 — Multi-function switch screw
6 — Multi-function switch electrical connectors (part of 14401)
7 3K359 Multi-function switch
Removal and Installation
  1. Remove the steering wheel.
  2. Remove the lower steering column shroud screw.
    1. Apply inward pressure to the upper and lower shroud cover seam to separate them and remove the lower shroud.
  1. Remove the 2 screws and the upper steering column shroud.
    1. Remove the screw, release the tab and position the multi-function switch aside.
  1. Disconnect the multi-function switch electrical connector.
    1. Remove the multi-function switch.
      1. To install, reverse the removal procedure.
This is how the service manual describes it.
Those that have replaced the switch know it is NOT necessary to remove the steering wheel or mess with the airbag. Check this video to see how to change it without the removal of the steering wheel etc.
While you work on your truck, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Score 2
Add a comment
Add your answer
Charles Harner will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 44
All Time: 571
