Join the Repair Community - Create Account
The Dell Precision 5550 workstation is a laptop made by Dell. This page contains repair and service information related to the Dell Precision 5550.
Dell fan making noise
How to fix noisy fan
Score 1
1 Comment:
A noisy Dell laptop fan is often caused by dust buildup, high CPU usage, or restricted airflow. Clean the air vents, place the laptop on a hard, flat surface, and close unnecessary background applications. If the noise continues, the cooling fan may need inspection or replacement by a qualified technician
by
Add a comment
1 Answer
@kglen there is never a good way to fix a noisy fan. I suggest that you replace it with a new one. your model should have two fans, and I would change both. Once one fails the other one is usually close behind. Remember that it's this relatively inexpensive component that essentially keeps your computer running safely. Also, make sure that all air inlet and heatsinks are properly cleaned and free of any major dust and debris. Use the Dell Precision 5550 Service Manual to work on it.
Add a comment
Add your answer
K_Glen will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 23
All Time: 429
