The HP EliteBook Folio G1, part of the EliteBook series, is a lightweight laptop designed for business professionals seeking performance and portability. It is powered by 6th-generation Intel® Core™ m processors, up to 8 GB of LPDDR3 RAM, and configurable M.2 SSD storage from 128 GB to 512 GB, with Full HD or UHD display options that include optional touch and IR support.
My usb port is not workig
my usb port is not workig
Score 1
Add a comment
1 Answer
@leonduop you are not giving us a lot of information here. We would need to know what you have checked and what you have tried. First you want to check your settings in the device manager and remove the old USB driver. Then either reinstall that driver or see if an updated driver is available. Now check your USB port.
If your physical port is damaged you know you will have to replace it. Now, you are using a singular term. LEt us know if this is only one USB port that has failed. If so, it's time to open your computer up and to check your motherboard for any damage. While you do so, take lots of well-focused pictures and post those with your Question. Adding images to an existing question That way we can see what you see. Also, let us know what the exact model for your motherboard is. We'll try and find some schematic that may help further with it.
To work on your computer use the HP EliteBook Folio G1 Maintenance And Service Guide
Add a comment
Add your answer
Leon Duop will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 14
All Time: 231
