Wireless communication devices, primarily used for referees.
Loose connection inside the rectangular rubber-coated case
Where would I start if I wanted to take this apart and re-solder it? Obviously would prefer to avoid any permanent damage. I've tried sliding a knife around the edges (there's a slight ridge where what appears to be two halves were pressed together), but I'm guessing I need heat and/or some kind of solvent. Anyone have experience taking apart weatherproofed / sealed electronics?
Score 1
2 Comments
@miketexter post a couple of well -focused images of the "rectangular rubber-coated case" with your Question. that way we can see what you see and hopefully assist you further. Adding images to an existing question
by
@oldturkey03 done, thank you for that tutorial :)
by
Add a comment
1 Answer
Most Helpful Answer
@miketexter that looks like it's very well glued together. If this would be mine, I'd take an exacto knife (or a razor blade) and cut through the seam. After completing the repair, I'd use some silicone rubber glue to reassemble the case.
Score 1
Add a comment
Add your answer
Mike Texter will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 13
All Time: 195
