Model A1312 / Mid 2010 / 3.2 GHz Core i3 or 2.8 & 3.6 GHz Core i5 or 2.93 GHz Core i7, ID iMac11,3
My problem is at Step 3
My problem is at Step 3, when I press the power button, the LED 2 lights up but when I leave the power button it turns off and the system also does not turn on. I have followed all the other steps after that and still nothing. Please suggest/help.
Thanks in advance.
2 Comments
What happened with your system?
by
Hey there, Step 3 of what guide?
by
Add a comment
1 Answer
Most Helpful Answer
Without more information it's hard to be certain what's gone wrong, but if you're only getting the first two diagnostic LEDs, then you may have an issue with the video card (something that is known to fail on the 2010 model). If the system is powering off immediately after releasing the power button, though, then that may indicate some larger issue, either with the power supply or the main logic board. Good luck!
Score 1
Add a comment
Add your answer
Dharmesh Thakker will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 174
