The Nintendo DSi is the third iteration in the Nintendo DS line, and made its debut in Japan in late 2008.
My dsi wont read games
one of my cusans was playing with it but wane he gave me it back it will not raed games
Score 6
1 Comment
Hi i have the same problem . I don't have an sd card and i put wifi and thats when the games didn't work anymore. I tried everything and it didn't work. I even formatted settings and everything still didn't work
by
Add a comment
Most Helpful Answer
Hey, the slot were the games go into is most likely damaged or needs to be cleaned. If you look in the slot, there is a door that needs to be lifted up and you can see the pins that read the game.
Shine a light into the slot and see if any of the pins are bent out of position or they have a green color corrosion over them.
If you see corrosion, then you can clean it with a nail file. Just be careful, so you do not bend the pins.
Score 4
1 Comment:
i might try it
by
Add a comment
Hi my DSI had the same problem, so did my sister's but hers is fixed. All she did was shake her DSI and then clean the slot with a tissue. It didn't work for mine sadly
Score 2
1 Comment:
Oh yeah and what door do u mean
by
Add a comment
well mine is a used one and it wont show
Score 2
Add a comment
I'm having the same problem :(
Score 1
Add a comment
No I found a game out side and it has a dent in it the chip is clean but my dsi xl won't read it
Score 1
Add a comment
I have the same problem
Score 1
Add a comment
Try putting a clothing tag in the game slot alongside the game. Yes, it does work, but it may take a few tries. It seems like it would break it more, I know, but I swear this happened to me and this was my solution.
Score 1
4 Comments:
whats a clothing tag?
by
*sweatdrop*
Um...sometimes clothes have those tags that are connected by little plastic tabs. Just, if you keep trying to get the game to work, putting slight pressure alongside the game card helps.
by
this is the only one here that helped me
by
Did yours have blended pins or was it just dirty?
by
Add a comment
Try spray compressed air in the slot. There may be dust bunnies inside.
Score 1
Add a comment
Hello, I am a YouTuber who has this same problem. As soon as I find a fix it will be uploaded on my channel here.
Hopefully, when and if I upload the video it will help you out.
1 Comment:
What door?I don't see a door
by
Add a comment
I have borrowed a dsi and simply blew into the game slot
Add a comment
I think DSI causes issues sometimes in reading games. You have to try it again and again and hopefully, it will help.
Add a comment
it could be dust in the slot. try using a cotton swab and rubbing alcohol in the slot. if that does not work, take it to a repair shop or if you know how to repair it, buy a replacement game card slot.
Add a comment
One possible solution is to clean the contacts on both the game cartridge and the DSi console using a soft, dry cloth. This can help remove any dirt or debris that may be interfering with the connection.
Add a comment
Add your answer
gaynordante will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 61
All Time: 41,627
