Repair and disassembly information for Samsung's flagship S21 Ultra Android smartphone, released in January of 2021.Also known as the Samsung SM-G998U1
Cracked screen flickers -temp fixes?
I broke my screen and there's a bit of glass missing on the edge. A horizontal line has appeared by the crack and the part of the screen below this often flickers green /goes dark. I found that if I play with it a bit it stops, especially I noticed if I push something fine in the crack it comes back to normal for a while (I have resorted to using the back of my earrings for this!).
I am not in a place to buy a new phone yet, and fixing this would cost about the same. My phone works perfectly besides this issue so I would like to use it as long as possible.
I've seen people suggesting to put glue or nail polish on cracked screen, but my hole is so deep I am worried this would ruin the whole screen.
Does anyone have suggestions on what I could safely put there that won't cause further damage?
Thanks !!
Score 1
Add a comment
1 Answer
Most Helpful Answer
you could try loca glue and cure it with a uv light as this glue is for bonding glass to lcd panels on phones, other than that a replacement screen is less than £80 on aliexpress
Score 1
Add a comment
Add your answer
Claudia Presti will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 21
All Time: 282
