The Xiaomi Redmi Note 9T is a mid-range smartphone by Xiaomi released January 2021. It has a 6.53" IPS LCD display, a 48 MP main camera, a rear-mounted fingerprint sensor, a 5000 mAh battery, and runs on a MediaTek Dimensity 800U 5G.
loudspeaker assembly lost after screen replacing
So when i replaced my screen,
i accidentally lost my loudspeaker assembly cover
and now my battery wont charge
phone was working well after replacement,
but now battery is not longer charging
if helps i change it with this screen :
https://www.emag.ro/ecran-compatibil-cu-...
sorry for my bad english.
Add a comment
1 Answer
The loudspeaker assembly pushes down on the connecting ribbon cable between the bottom circuity (USB board) and motherboard. If your device was charging right after your reassembly, then the cable is most likely not damaged.
However, due to the missing loudspeaker assembly, it most likely came loose. The best fix here would be to source a new loudspeaker assembly and replace it.
There are a couple other DIY options, though. One would be glue, silicone or other more heat-resistant non-conductive elements that would hold it in place. These DIY solutions will most likely be permanent, though.
You could also try opening it again, then taping the connector down with some Polyimide Tape and seeing how that sticks.
Add a comment
Add your answer
alex oare will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 24
All Time: 202
