Compaq 610 window 7 update to window 11
How can I update window 7 of Compaq 610 to window 11?I have tried several times but it fails kindly help me
Hi,
Unfortunately your Compaq 610 isn’t capable of running Windows 11.
It may not even be capable of running Windows 10 but you can try.
Whilst you may have success with Windows 10 you might find that it doesn’t run very well & you may have compatibility problems with some components & driver issues.
If you need to have access to a more modern web browser and other programs that no longer function on Windows 7 then you would be best of installing Linux OS to extend the life of the laptop.
You can google Linux OS on YouTube to learn about it and how to install.
There are lots of them but the most newbie friendly ones are:
Ubuntu Linux
Linux Mint
There are so many more and each one has several different desktop versions, some are similar to Windows and they also have light versions that will run on really old machines.
One in particular is AntiX Linux for 32 but & 64 bit.
You just need to watch a few videos to start getting the idea of which one will suit you & you laptop better.
You can also find lots of information at:
disrowatch.com
It has listings and reviews as well as downloads for each Linux OS release, there are also ares for learning command line use etc.
Hope this helps
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 26
All Time: 411
@kerrenyongs are you upgrading or doing a new install? Does it give you any kind of error or what happens when you try?
by oldturkey03
