Model A1311 / Mid 2010 / 3.06 & 3.2 GHz Core i3 or 3.6 GHz Core i5 Processor
Housing/ stand compatible with 2009 iMac?
I previously had a 2009 imac, which the display randomly broke on it giving me grey screen no matter what. I have now purchased a 2010 iMac which has a broken stand. is it possible to swap the housings and/or stand between the 2? also i assume that my ssd from the 2009 is just plug in and works right? or do i need to do extra work?
Add a comment
1 Answer
Most Helpful Answer
It’s a far amount of work to get to the hinge which is inside the housing. Even still that’s what I would do.
As far as your SSD that should be fine. Depending on what the new system has for RAM I would boost it to 16GB while in there.
Basically, just follow this guide as the foot hinge is just behind it iMac Intel 21.5" EMC 2389 Logic Board Replacement
Score 1
Add a comment
Add your answer
Sam will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 24
All Time: 109
