iPod Classic 6th Generation. Model A1238 / 80, 120, or 160 GB hard drive / black or silver metal front
Playback glitches unless connected to power
Overview:
My SSD upgraded iPod will fail to play songs and skip multiple at once - the songs it does play will only play for a couple of minutes before a brief silence followed by the song skipping before the end. However, the iPod works fine when connected to power - i.e. in the car via USB connection or wall plug.
History:
I chose to replace the HDD after it corrupted and was not recognised by my PC. Previously no playback issues were experienced (until the HDD corrupted). The replacement SSD can be found here. A larger capacity replacement battery was also fitted.
Edit: Could be worth noting that original capacity was 80GB, with replacement SSD increasing to 128GB.
Thoughts:
At first I thought this could be a battery issue, however upon changing back to the original battery the issue still persisted, except for when connected to power (same situation as the replacement battery). The iPod doesn't actually show its connected to power when plugged in, however as soon as the cable is removed, the play back issues return. Also, I am confident the files on the iPod itself are fine/not corrupted, as they all play without issue when connected to power.
Anyone have any ideas where the problem could be?
Thanks for your help!
Add a comment
1 Answer
I still suspect a power issue here. The difference between Battery alone Vs powered via USB as well aims us clearly at a power issue.
I would see if CoconutBattery was able to see the battery when you connect the iPod to your Mac. I’ve never tried so I’m not sure. Post a question to Chris maybe he can tell you if it would work (his email is in the link). Post a snapshot here for us to see if it works! Maybe it will offer us a clue on what is happening.
3 Comments:
Thanks for your response Dan, currently Coconut Battery is not detecting the iPod - Im awaiting response from Chris to see if there is a work around.
See response from Chris:
No, the iPod classic is technically incompatible with the app
by
@adam0170960 - I was hoping😢
So for the sake of argument, if the power is not enough, could it be the SSD is pulling too much power Vs what the original micro HHD was pulling?
by
A valid point, although I would assume that iPod Parts UK would supply an SSD that draws suitable power? Otherwise I imagine many others who opt for their SSD replacement would also be experiencing issues.
I have contacted the supplier in the case that the SSD might be at fault, maybe they can organise a replacement.
by
Add a comment
Add your answer
Adam_01 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 13
All Time: 265
