Teardowns and repair information for iFixit tools.
2.5 mm Nut Loctite to socket
So I was working on a set of sunglasses with my 2.5mm socket bit and had dabbed loctite on the threads of the bolt, (because no matter how many times I tighten the nut it still seems to loosen) somehow the loctite has secured the bolt to my sunglasses but the nut is secured into my driver. Any ideas on how to get the nut out?
Add a comment
Did you try some solvent or heat? I would cover the plastic parts to prevent damage either from the solvent or heat.
Add a comment
@drfusion3000 get a long screw that fits the thread of the nut. Screw it in and get some locking pliers. You can use a second pair of those to hold the driver. You now have more leverage. Now you can try and apply some heat. A heat gun will be needed since a hair dryer won't supply enough heat to loosen loctite. Depending on which product you've used, you are looking at temps around 325F for the standard (BLue)loctite and 500F for their better threadlocker (Red). Use the "screw extension" and the locking pliers to try and pull the nut free,
If it still won't budge (or you can't apply the heat), there are commercial adhesive solvents available, that will even take care of loctite products. Something like Acetone or MEK (Methyl ethyl ketone) solvent will work (depends on where you reside, it may be unavailable), as well as a commercially available Super Glue Remover (most departments stores sell the Goof Off brand). Loctite itself sells a remover (LOCTITE SF 7601) but it costs a fortune :-)
Add a comment
Add your answer
DrFusion3000 will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 10
All Time: 165
