Up to 20% off select tools
Apple's mainstream 2020 iPhone was released October 23rd and comes with a 6.1" OLED display, a dual 12 MP camera system, and in five available colors. Successor to the iPhone 11.
Kernel Panic Missing sensor(s)
Missing sensor(s)
Update (09/07/24)
"panicString" : "panic(cpu 2 caller 0xfffffff02c62b8e8): userspace watchdog timeout: no successful checkins from thermalmonitord\nservice returned not alive with context : is_alive_func returned unhealthy : current 5fffffffff, mask 3fffffffff, expected 3fffffffff. SD: 1 BC: 1 RC: 0 BS: 1, Missing sensor(s): Prs0 \nservice: backboardd, total successful checkins in 194 seconds: 19, last successful checkin: 0 seconds ago\nservice: SpringBoard, total successful checkins in 169 seconds: 17, last successful checkin: 0 seconds ago\nservice: mediaserverd, total successful checkins in 194 seconds: 18, last successful checkin: 0 seconds ago\nservice: logd, total successful checkins in 194 seconds: 19, last successful checkin: 0 seconds ago\nservice: thermalmonitord, no successful checkins in 194 seconds\nservice: runningboardd, total successful checkins in 194 seconds: 19, last successful checkin: 0 seconds ago\nservice: wifid, total successful checkins in 194 seconds: 18, last successful checkin: 0 seconds ago\nservice: configd, total successful checkins in 194 seconds: 18, last successful checkin: 0 seconds\nDebugger message: panic\nMemory ID: 0xff\nOS release type: User\nOS version: 20H115\nKernel version: Darwin Kernel Version 22.6.0: Wed Oct 4 21:55:46 PDT 2023; root:xnu-8796.142.1.701.11~1\/RELEASE_ARM64_T8101\nFileset Kernelcache UUID: C5D2A5F46EB1E5A63AF8FDE73B4AD5E9\nKernel UUID: 510BBA43-3466-3323-88BD-6B231BB89712\nBoot session UUID: E97F1F8E-97D5-4524-9CA0-BAE7D1C681B7\niBoot version: iBoot-8422.142.2.700.1\nsecure boot?: YES\nroots installed: 0\nPaniclog version: 14\nKernelCache slide: 0x0000000023fa4000\nKernelCache base: 0xfffffff02afa8000\nKernel slide: 0x0000000023fac000\nKernel text base: 0xfffffff02afb0000\nKernel text exec slide: 0x0000000024d14000\nKernel
Update (09/07/24)
Update (09/07/24)
Add a comment
Most Helpful Answer
Tarun (@tarun66510), it would help if you could confirm that we're talking about the same model phone as the original poster, since you cut off the beginning of the log showing that information.
Anyway, I can't tell offhand if these are three separate log entries, or if you've just posted the same one three times; either way they all say the same thing so only one is really needed.
Now when we take a look at the log itself we see exactly what was in the original poster's log, that the PRS0 pressure sensor has failed. So the fix for you is exactly the same as the fix for the original poster; replace the charging port assembly. Read my previous answer for details. Restart every 3 minutes after water
Score 1
Add a comment
Hapus semua data panci full
Add a comment
Add your answer
Tarun will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 42
All Time: 757
