The HP EliteBook 840 G4 is a sleek 14-inch laptop made for working professionals. It runs on Intel’s 7th-gen Core processors, has a slim aluminum body, and includes solid security features for business use.
My battery died fast
my laptop battery died fast and its just charge for 80% and its died also when it close
Score 1
Add a comment
1 Answer
Hi,
Your laptop has been around since 2008 and I would suggest it has already had a battery replacement at some time in the past.
Depending on when it was last replaced, it’s more than likely the current battery is no longer capable of taking full charge or holding charge any longer.
If you have more recently replaced the battery it’s possible that it wasn’t a good quality battery or has developed an internal issue that affected its ability to perform as it should.
The other thing you may need to check is the charging power supply, as it may no longer provide enough charge voltage or current due to fatigue or cable damage.
You could try another charging plug pack & cable if you have access to one.
You may need to either have the charge pack & cable & battery tested at a repair shop.
Or if you know the battery hasn’t been replaced for a long time and your charging pack is functioning properly, buy a replacement battery.
Hope this helps
Add a comment
Add your answer
Mohammad Khair Al-Sairafi will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 15
All Time: 198
