The Sony WH-1000XM5 were released on May 20 2022. Over-the-ear headphones, noise cancelling headphones by Sony.
My left headphone has died
Hi everyone i am looking to get some direction on what i should replace for the headphones. I had the issue where the left earpiece had some crackling and ocassional cutting in and out and then proceeded to die completely. Should i replace all the parts in the left earpiece ? or is there a specific part to replace to fix this issue
Add a comment
1 Answer
@gavinferna53286 the very first thing I would do is to double check all the solder joints. It would also be prudent to resolder all of the wires. You'd be amazed to see how many of the frail wires are actually breaking and causing the exact same issues. If all of that will not fix your headphones, then consider replacing the driver (speaker)
Add a comment
Add your answer
Gavin Fernandes will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 21
All Time: 438
