Up to 20% off select tools
A range hood is a kitchen appliance installed over the stove, designed to remove smoke, odors, heat, and airborne grease through filtration and ventilation.
Interlock Switch Bracket Installation
Anybody know how difficult it is to replace an interlock switch bracket (lower switch bracket assembly, part # 97009972) on a Kenmore Downdraft Vent/Blower (model # 233.5994690)? Do you have to remove a few panels to access the interlock switch or is it more involved?
Add a comment
1 Answer
here is the diagram. You will have to figure out how hard it is to replace.
Item 10 is the switch. It is a V7-1B17D8-048 which is available from sources other than the Kenmore.
1 Comment:
Thanks. I've got that schematic and am thinking to replace the interlock switch bracket assembly you probably need to nearly take the whole thing apart. Hoping someone can confirm/refine that assessment before I decide what action I'm going to take.
Thanks again
by Share
Add a comment
Add your answer
James Brooks will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 22
All Time: 263
