Up to 20% off select tools
The Nintendo GameCube Controller DOL-003. Released November 2001, compatible with Nintendo GameCube and the Nintendo Wii, and to a more limited extent, the Nintendo Wii U and Nintendo Switch. Repair for this device is straightforward and requires only common tools.
Gamecube controller stops working after a while.
Hi everyone,
it seems my Gamecube controller stops working after a while.
Strangly, I can move the analog stick freely forever, but once I press 'A','X','Y' or 'B' button, the controller stops working very soon after.
I am wondering if anyone had that problem. Thanks in advance for your help !
Add a comment
1 Answer
Most Helpful Answer
Hi!
This is strange! Something must have happened on the motherboard! Please clean the board first with isopropyl alcohol. Then check for the damage on the motherboard. Also please clean the rubbers (maybe replace them while you are there). And then try again.
If the issue still persist, then you could replace the motherboard (hard to find, I know). Or you need to check again for damage/missing components/ broken traces.
Score 1
Add a comment
Add your answer
Nickmaiden will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 28
All Time: 204
