The Kindle 10 was released by Amazon in 2019 with the model number J9G29R. The Kindle 10 is also known as “Kindle 10th generation”, “Kindle 2019”, “Kindle Basic 3”, or “Kindle Basic 2019.” It uses E-ink technology and has a capacitive touch screen. It comes in two colors, black or white.
broken screen, is there any solution?
My Kindle stopped working and stayed that way, I have tried to fix it by disconnecting everything and it doesn't work.
Score 1
Add a comment
1 Answer
Chosen Solution
Hi @bvsty
You may have to replace the screen.
What is the model number of the tablet as shown at the bottom of the back cover?
Not all Kindles are the same i.e. different LCD flex cables/connectors etc, so knowing the model number will ensure that you get the correct replacement part.
Score 1
5 Comments:
Is the modelo J9G29R
by
@bvsty
See the Most Helpful Answer to this question on ifixit for help to fix your model.
by
Thanks for the help.
by
Hi, I have the model J9G29R and it has a broken screen. I have a replacement screen. Was able to open up the kindle based on below guide but I have not been able to find any videos to show how to actually remove the screen to replace it - it appears to be glued on or something - any help??
here is ifixit guide on how to disassemble the kindle
Kindle 10 Display Assembly Replacement
- thanks
by
where did you get the replacement screen from? I can't find anything online
by
Add a comment
Add your answer
Bvsty will be eternally grateful.
Past 24 Hours: 4
Past 7 Days: 10
Past 30 Days: 44
All Time: 605
