LDS malfunction when turned on
My Ecovacs DEEBOT OZMO 920 2-in-1 has been experiencing a LDS malfunction over the last couple of days. The associated application notifies me of the LDS malfunction but provides no specifics. So far, I have only been able to understand that the LDS sensor helps the device map the area and the LDS malfunction prohibits it from doing so and the cleaning process cannot start.
I need help understanding the specifics of the error, procedures to inspect the sensor and determine the parts which need to be replaced.
Add a comment
1 Answer
The laser distance sensor is the rotary laser on top if the unit. Make sure the clear plastic housing is clean, and if this does not help, I would make sure it's wires are correctly seated before trying to replace it.
Add a comment
Add your answer
Apurva Bafana will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 14
Past 30 Days: 57
All Time: 791
