The Samsung Series 5 NP540U3C-A02UB is a laptop released by Samsung in 2012 running Microsoft Windows.
New Laptop battery not Charging
New Laptop battery not Charging.
Tried:
Cold power cycle
Laptop off overnight while plugged in
Checked BIOS setting.
Deleted and reinstalled Microsoft ACPI-Compliant Control Method Battery device driver.
Battery icon says: "Power Mode (Plugged in)" 36%
The battery replaced would charge. Replaced as it died in less than hour.
Thanks
Jim
Add a comment
1 Answer
Most Helpful Answer
Hi @jim84536
If you have Win10 (or Win11) installed, create a battery report to check the condition of the battery.
When you have the report, compare the Design Capacity value, versus the Full Charge Capacity value as shown by the report.
For a good battery they should nearly be the same values. You can work out as a percentage the condition of the battery by using the formula Full Charge capacity value x 100 รท Design Capacity value.
It could just be that you got a faulty battery. Unfortunately it does happen.
Score 1
Add a comment
Add your answer
Jim will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 6
All Time: 200
