The Sony DualSense Edge (CFI-ZCP1) wireless controller was released in January 2023. It features replaceable joystick modules and other upgrades from the DualSense.
Stick Module always out stock, Any possible Solutions?
With the Stick Module impossible to get, I was thinking of just replacing the potentiometer with a hall effect one is that possible? are the hall effect available in the market compatible with the module
Score 1
Add a comment
1 Answer
Chosen Solution
Hi!
I’m afraid you need to replace the whole joystick to get that to work. Unfortunately you need to complete de-solder the old one and solder the hall effect joysticks in. But it is worth it!
Score 2
6 Comments:
so open up the module i have, i understand soldering part i dont mind. But is the hall effect compatible with the stick modules for the DualsenseEdge.
by
Ohh sorry, you want to know if the Hall effect joysticks are compatible with the Dual Sense controller, right? The answer is, yes, they are! Part: https://www.aliexpress.us/item/325680609...
by
Thank you! i was able to order one yesterday arrived today. Now the challenge is removing the soder in the module. it is In there pretty deep.
by
My pleasure! Yes, this is the most difficult part. They are soldered on with "lead free" solder. So you need to turn up the heat to 400-450 to get it out. Once it is out, you can solder the new one back in which is easier to do! Good luck with the repair!
by
So, did it work? Is it much different from DualSense modules?
EDIT: and do you need to get Edge-specific module replacements or classic DualSense will work too?
by
Show 1 more comment
Add a comment
Add your answer
SlicedAnddiced will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 14
All Time: 1,430
