The Raspberry Pi 4 is a versatile single-board computer developed by the Raspberry Pi Foundation and is the fourth iteration of the Raspberry Pi line of products.
USB ports are dead
Hi guys. I have a RaspberryPi 4B 4GB (newer version) that had 9V instead of 5V put through the USB-C power input according to owner.
Surprisingly it boots and works, but ethernet and USB ports are dead. I replaced the BCM54213PE and VL805 chips I took from a donor board - ethernet works fine now, but no luck with USB.
I also replaced the crystals next to both of those chips - didn't help either.
Any ideas what else I should check?
Add a comment
Chosen Solution
Fixed it in the end :) So in total I replaced both chips and also quartz crystals next to them on both sides, then also replaced a diode next to the Ethernet port and USB 3 and two chips that look like filters between the BCM54213PE and PoE.
None of that actually did the trick in full, so then I reflowed VL805 IC and voila - "we have picture" (c) Sorin :D
Score 1
Add a comment
Did you post your question in the Raspberry Forum area?
I would check the power side of the USB sockets is power getting through? Does a powered USB hub allow the USB device to work?
1 Comment:
Oh absolutely, thanks, but actually I already figured it out :) thanks for the heads up anyway :)
by
Add a comment
Add your answer
in_sympathy will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 53
All Time: 966
