Up to 20% off select tools
Released in 2012, this is a durable PC laptop for the everyday computer user. This model (NP540U3C-A01UB) features a 13" screen, a 500 GB hard drive, 4 GB RAM, a DVD multi-drive and is capable of running Windows 8.1.
Stuck in bios settings
My laptop is just stuck in bios setting every time i switched on, how can i fix it so that when i switch on it should boot and not stuck in bios setting?
Add a comment
1 Answer
You are already in the BIOS Settings but for others press F2 after powering on.
Stuck in BIOS? It is likely trying to tell you something.
When you click "Boot" on the menu does your boot drive show in the Boot Menu list?
Under [Boot Priority Order] there should be SATA SSD or SATA HDD.
Either of those should be at the top of the list. F6 moves them up or down and F10 saves the settings.
Let us know what you find so we can help you further, if needed.
Add a comment
Add your answer
Austin Zulu will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 18
All Time: 232
