Glue panel back together?
So I had this monitor for some time now, and the lcd panel started detaching from the backlight. Any suggestions on what type of double sided tape or glue I could use?
Score 2
Add a comment
1 Answer
Chosen Solution
@alenortiz don't use glue since it will only make a mess. I would use a tape adhesive and tape it over the screen/case along the seam, to keep things safe. Easier to remove and a whole lot less mess. I prefer a good nylon tape or even some decent Gaffers tape. Should be available at any good hardware store or even a fabric store.
What makes me wonder is, why is it separating....
Score 2
2 Comments:
Nylon tape sounds like a good option, thanks a lot, I will give it a try… and I don’t wanna say it started separating because of built quality, but maybe the environment, I had to install a dehumidifier because of how muggy it gets.
by
@alenortiz yep, that definitely does do it. Humidity and tempos are a killer of our electronics, Stay safe !
by
Add a comment
Add your answer
Alen Ortiz will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 33
All Time: 592
