Up to 20% off select tools
Little machines by Jura. There are different models, but the repairs are almost the same.
Machine keeps saying press rinse
Machine says press rinse repeatedly
Score 1
Add a comment
1 Answer
Most Helpful Answer
When you rinse, does water come out? So my first idea is the flowmeter. Is it perhaps clogged and therefore not reporting any water flow to the electronics? Open the machine. Step 12, first picture shows the flowmeter, the small white round box next to the brewing unit. Open it and clean it, as described e.g.here.
Jura ENA micro 9 Image
Guide
Jura ENA micro 9 opening procedure
Difficulty:
Moderate
Jura Impressa S85 Flowmeter Image
Guide
Jura Impressa S Model Flowmeter replacement
Difficulty:
Moderate
Score 1
2 Comments:
This totally saved my Jura from sending it in for repairs thank you so much although what happened was I did everything,cleaned it put it back together and it still kept saying rinse. I reversed the tubes because I wasn’t sure if I put them incorrect and tried it a few more times it kept saying the same thing so I figured I was going to send it in but then I reverse them back again to the proper way and now it works like a charm. Maybe it just needed to unclog something and the reversing of the tubes did that. in any event thank you very much.
by Share
@kimwoodbridge So the flowmeter - as often - was the culprit. The channel where the water flows in is very narrow, for sure it was clogged. Congratulation to your repair!
by Share
Add a comment
Add your answer
John will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 17
Past 30 Days: 65
All Time: 1,260
