What should I do with E4?
After working for a few minutes, it starts beeping and shows error 4 on the screen, I don't know how to fix it.
Update (07/18/24)
Yes, you have a GE GBT412SIMII model dishwasher.
Is there standing water under the tub at bottom of the dishwasher?
If there is then it may be due to a leak in the dishwasher which has activated the flood switch
If there's no water it could be a faulty flood switch.
Tilt the dishwasher forward and check if any water drains out.
Unfortunately I cannot find the service manual (look behind the kickplate -toe plate to see if it is there in a plastic sleeve) or any parts for your model.
There is no standing water under the tub at the bottom of the dishwasher. The dishwasher continuously drains, and if I add water, it drains immediately, making a sound as it does so. Since the dishwasher is built-in, I need to remove it to check further, but I don't have a screwdriver to take it out.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 31
All Time: 439
3 Comments
Hi @babakvakilian
What is the model number of the dishwasher?
by jayeff
Hi @jayeff and thank you , is it correct ?
by Babak Vakilian
by Babak Vakilian
