Find repair and more information about the LG LFX25976** refrigerator, a bottom freezer style model with both drawer and door access, and an automatic defrost system. This page covers information for model numbers matching the pattern LFX25976**.
Bottom freezer leaking and then freezing
Water is leaking into the bottom freezer, and then freezing. This prevents the door from closing all the way and then the whole freezer starts ice crystalling. There is no water lin nor ice maker hooked up. I opened back panel, vacuumed everything out. The fan is working, the drain pan is dry. What should I check next? (Also I could not find specific diagram for the coils and drain lines, plugs. I was going to check for a clog.)
LG LFX25976ST
Add a comment
Most Helpful Answer
Hi @beach757
Here's a video that shows how to replace the drain tube extension, where it exits the cabinet above the drain pan.
Check to see if the defrost meltwater is getting to the pan.
If not, the drain tube inlet is under the evaporator unit, behind a panel inside at the back of the freezer compartment, check that it is not blocked there.
Here's a video that shows how to replace the defrost heater that may help. I realize that this isn't the problem but the video shows how to access the evaporator unit as the heater is under it,
Score 1
Add a comment
I think you likely have an issue with your door gasket. If the seal is compromised, moisture in the air can seep in and freeze over time which will lead to the problems you mentioned. I would inspect them thoroughly for any rips, tears, or damage that would support this. It's a relatively cheap and straightforward fix.
Freezer: LG Refrigerator Freezer Door Gasket - MDS64172919
Door: LG Refrigerator Door Gasket Assembly - ADX72930460
Seals the freezer door to prevent air leaks and maintain proper temperature in your LG refrigerator. Image
Product
$65.99
Creates a tight seal around the refrigerator door to prevent warm air from entering. Image
Product
$94.99
2 Comments:
I found water dripping from the vents on the back wall of the bottom freezer. Does anyone have specific diagram info for the defrost drain, freezer drain? I think there's a clog.
Model LG LFX25976ST
by
Add a comment
Add your answer
Beach757 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 43
All Time: 685
