Up to 20% off select tools
Discover repair information including guides and tips for GE Stoves, Ovens, Ranges and Cooktops. We offer detailed instructions for troubleshooting and fixing common issues in various GE stove and oven models.
Ge monogram oven problem
Probe light kept blinking on and off on display and couldn't start oven. Replaced probe and receptacle, still blinks. Should I replace the control panel board or main machine board?
3 Comments
This question was migrated from https://meta.ifixit.com/Answers.
by Share
Hi @bob57707,
What is the model number of the oven?
by Share
@jayeff hi, model number is zet1sh1ss
by Share
Add a comment
1 Answer
Most Helpful Answer
Hi @bob57707
Here's the mini manual for the oven.
It shows how to test the temp sensors to prove that the sensor wiring and the sensors are OK back to the board, - see Oven Sensor and Door Switch Ohmmeter test on p.1
If they test OK run the service test mode as described on p.2 and check what error code is shown (if any) when testing the components.
If a part is faulty and needs to be replaced, here's a parts list that is useful as it shows the manufacturer's part number listed for each part.
Search online for the part number only to find suppliers that suit you best.
Score 1
Add a comment
Add your answer
Bob will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 19
All Time: 518
