14" - Core i3 2310M - SUSE Linux Enterprise Desktop 11 - 2 GB RAM - 500 GB HDD
System turns off at 100% processor power
Why does my laptop overheat when I set my processor power to 100%
Add a comment
1 Answer
Most Helpful Answer
Hi @osborn92573,
Does the fan speed up (or get louder) after you've done this?
Perhaps the fan needs cleaning and also the thermal paste on the CPU needs to be refreshed, so as to maximize the heat transference from the CPU to the heat sink and fan where it can be expelled from the laptop, allowing the CPU to operate within its specified temp range.
Here's the maintenance and service guide for the laptop. Go to p.83 to view the procedure to remove the fan/heat sink assembly.
This will enable you to gently clean the fan and also to refresh the thermal paste on the CPU as it has most probably dried out.
Here's the ifixit How to Apply Thermal Paste guide that may also help.
Score 1
Add a comment
Add your answer
Osborn will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 17
All Time: 183
