Up to 20% off select tools
The Oppo Reno7 5G is a smartphone designed by Oppo. The phone were released in 2022.
How to fix screen touch sensitivity
when playing games sometimes its hard to press because it doesnt function. And sometimes the touch screen had delays
Score 11
1 Comment
My phone is very hot.
by Share
Add a comment
Most Helpful Answer
Hi @onij
Set the adjustment of the Touch and hold delay setting to what you want.
Go to Settings - System settings - Accessibility - Personalized settings - Touch and hold delay.
If you can't find the setting, to turn on the Accessibility and menu settings go to Settings - System settings - Accessibility - General - Accessibility Menu. To open the Accessibility Menu, tap the icon in the lower right corner
Score 2
Add a comment
Battery repair
1 Comment:
Fateh, you're going to have to give us more than two words if you want help. By "battery repair", are you saying you want to replace the battery? Is your phone the same as that of the original question? Have you verified the battery is the problem and not the charger, the cord or the charging port? Have you tried a different charger?
by Share
Add a comment
Add your answer
ONiJ will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 78
All Time: 4,628
