The seventh-generation Golf had its début in late 2012 at the Paris Motor Show.
Airbag light not going out
I took the seats out of my mk7 to clean the carpets and after connecting everything back up , the dash is showing an airbag fault. Any ideas..?
Add a comment
1 Answer
Most Helpful Answer
Hi @zarliwoop
Looking at the body interior section of the repair manual, the battery needs to be disconnected and also a special air bag lockout adapter needs to be fitted to the wiring harness under the seat before commencing to remove the seat. (see p.429 → of the manual)
Also it appears that if there's an airbag indicator light after reinstalling the seat, the error needs to be cleared from the DTC (diagnostic trouble code) memory using a diagnostic tester unit - see p.438 of the manual.
You may have to go to a dealer to get it cleared.
Score 1
Add a comment
Add your answer
Zarliwoop will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 26
All Time: 202
