The Miyoo Mini is an open-source handheld game console launched by Miyoo in 2021. It runs OnionOS and supports many retro game consoles, from the NES to Original PlayStation.
Why is my screen black
i believe i miss up my miyoo mini it was in miyoo ui and i put a onoin os sd card with an update it install but the screen turn black it turns on i can here sounds still just i can see anything I tried putting the old sd car with ui in it nothing i turned it off and turn it off and on still nothing I know it is dumb but i didnt know this would happen. you think it is fix able
Add a comment
1 Answer
Most Helpful Answer
Hi!
This is most likely an software issue.. So if I'm correct, it failed after you've tried to install a firmware update for this device?
If this is the case, the best thing to do is to contact Miyoo. You could replace the motherboard to fix it, but this will be expensive.
Hopefully Miyoo do have something to re-flash the device so that it can be used again instead of replacing the motherboard....
If you are wondering regarding the motherboard replacement, here is a video: https://www.youtube.com/watch?v=6R2h4kfW...
Please let us know how it goes!
Score 1
2 Comments:
This is for the miyoo mini plushic i have the regular small one wh is the miyoo mini not the plus but thank you for your help
by
Hi! My pleasure! Is this the video for your model? https://www.youtube.com/watch?v=97kOOxP3...
Have a nice day!
by
Add a comment
Add your answer
Flux will be eternally grateful.
Past 24 Hours: 4
Past 7 Days: 10
Past 30 Days: 27
All Time: 1,040
