Repair and disassembly information for Google Pixel Buds Pro wireless earbuds, released in July 2022. Identified by models GA34L, GQGM1, and GPX4H.
Squealing/Sqeaking in left bud
My left earbud has a repetitive squealing/squeaking sound when used in either noise cancelling mode. If i turn off NC, the sounds goes away. The volume in the left side also seems quieter. I have had this issue once before more than a year ago when they were under warranty where I sent them in for successful repair (or whatever they did). I suspect that earwax builds up inside the buds under the protective screen over time but can't verify without removing the screen. I'm willing to do some disassembly if it might fix them. Any suggestions?
Score 5
Add a comment
Most Helpful Answer
I had this exact problem in my right earbud. There are 3 mesh grilles on the outside, the top two are used for noise cancellation mics. I assumed the consistent squeaking was because of microphone feedback caused by earwax or sweat buildup, so I cleaned them out with isopropyl alcohol, and the problem got slightly better, but didn't go away entirely.
It wasn't until I used isopropyl alcohol on the speaker mesh, the one inside the tip. I just got some paper towel with 93% IPA, dabbed them a bit, then blew it out with some pressurized air, and now they're back to normal.
Score 8
5 Comments:
IPA - craft beer cures everything ;-)
by
My left pro bud is driving me insane. I've tried everything mentioned and called Google support. Out of warranty. As a thank you for being a loyal customer they gave me a 20% discount in the Google store. I just want it replaced... So annoyinh
by
Magic!!! Resp and chapeau to you, Cameron! This solved it absolutely immediately. I'm utterly impressed and thankful. Have yourself a great day!
by
Thank you very much. It works for me perfectly. In my case, I think my sweat during running flooded the ear buds, causing the issue.
by
I had the same problem on my right earbuds which was driving me mad. I just disconnected the buds from my pixel phone and used the forget device option. Added the device again and set it up with the pixel buds app and now both the earbuds are working just fine with nc or transparency mode.
by
Add a comment
I was able to fix this by re running the Eartip Seal Check on The Pixel Buds App.
Add a comment
Add your answer
PCON will be eternally grateful.
Past 24 Hours: 10
Past 7 Days: 53
Past 30 Days: 239
All Time: 7,408
