Repair and disassembly information for the Samsung 55" UHD television with model numbers UN55MU6290xxxx. Released in 2017.
TV started misbehaving (see video below)
TV is useless the image fades out all the time, see video below. is there anything I can do about it?
Score 1
Add a comment
1 Answer
@letserherrera that is most likely a panel error. There is of course the slight possibility that this is caused by a overheating GPU on your main board but the way the picture fades, it's most common of a panel error. It is most likely a loss from teh LCD driver boards. You could try a Tape_off and see if that changes anything. Let's try something first. Remove the back panel. Then with the TV unplugged, remove one of the ribbon cables from the LCD driver boards. Now try and turn your TV on. Note exactly what your TV does. Then unplug the TV and reconnect the ribbon. Next disconnect the other ribbon, plug your TV in and restart. Let us know what you get with this.
1 Comment:
Thank you!, I'll try it as soon as I have a chance.
by
Add a comment
Add your answer
Letser Herrera will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 10
All Time: 164
